FLEX-5000A and FLEX-5000C Transceiver Specifications
Expand / Collapse
System Dependencies
Minimum PowerSDR Version:
  N/A
Applicable Hardware:   FLEX-5000
Content provided by:  FlexRadio Systems Engineering
General
Rx Frequency Range:
10 KHz - 60 MHz
(Customer provided preselector or appropriately selected low pass filters required to eliminate images when used below 1.8 MHz)
160 - 6 m (specified performance, Amateur bands only)
Transmitter Frequency Range:
160 - 6 m (Amateur bands only)
Frequency Stability:
±0.5 ppm 32 °F to 122 °F (0 °C to +50 °C)
Ambient Operating Temperature Range:
14 °F to 122 °F (–10 °C to +50 °C)
Emission Modes:
A1A (CW), A3E (AM), J3E (LSB, USB), F3E (FM),
F1B (RTTY), F1D (PACKET), F2D (PACKET)
Frequency Steps:
1Hz minimum
Antenna Impedance:
50 Ohms, unbalanced
6 - 1000 Ohms, unbalanced (With Optional Tuner ON, 160 - 10 m Amateur bands)
16 - 150 Ohms, unbalanced (With Optional Tuner ON, 6 m Amateur band)
Power Consumption:
Rx 1.5A (typ.); Tx (100 W) 25A (max.)
Supply Voltage:
DC: DC 13.8 V ± 10%
Maximum Interconnect Cable Length:
Firewire - 10 feet (3m),
No restriction on DC power cable within voltage tolerance limits under load.
Special EMI/RFI Requirements:
NOTE: Necessary to minimize RFI radiation from the cables attached to the radio
1 snap on ferrite bead on DC power cable,
2 snap on ferrite beads on FireWire® cable
1 snap on ferrite bead on FlexWire™ cable
All beads to be located adjacent to rear panel of radio.
FLEX-5000A Dimensions:
(WxHxD): 9.3” x 8.7” x 13.8” (23.5 cm x 22.1 cm x 31.5 cm)
FLEX-5000A Weight:
(approx.): 13 lbs (5.9 kg)
Transmitter
Power Output:
1 - 100 watts PEP CW and SSB (2 - 25 watts AM carrier)
28 MHz IF Power Output:
0 dBm (1.0 milliwatt)
Emission Modes Types:
A1A (CWU, CWL), J3E (USB, LSB), A3E (AM), F3E (FM), DIGITAL
Spurious and Harmonic Radiation:
Better than –55 dB (160 - 10m Amateur bands)
Better than –65 dB (6m Amateur band)
SSB Carrier Suppression:
At least 55 dB below peak output
Undesired Sideband Suppression:
At least 60 dB below peak output
Audio Response (SSB):
90 Hz @ -3dB / flat to upper limit set by software, Software EQ optional
3rd-order IMD:
Better than –33 dB below PEP @14.2 MHz 100 watts PEP
9th-order IMD:
Better than –54 dB below PEP @14.2 MHz 100 watts PEP
Image Rejection:
88 dB
Microphone Impedance:
600 Ohms (200 to 10k Ω)
Balanced Line In Impedance
Receiver
Circuit Type:
Direct conversion, low IF
Intermediate Frequency:
Software selectable from DC to 20 KHz
Sensitivity (preamp off/on):
1.3/0.3 µV at 14 MHz
MDS (preamp off/on):
-123 dBm/-133 dBm in 500 Hz BW
IMD DR3 (dynamic range):
99 dB at 14 MHz with preamp off or off at 2 kHz or less tone spacing
IP3:
+30 dBm at 14 MHz with preamp off at 2 kHz or less tone spacing (S5 IM3 test method)
+39 dBm at 14 MHz with preamp off at 2 kHz or less tone spacing (ARRL test method)
IP2:
+63 dBm at 14 MHz with preamp off at 2 kHz or less tone spacing (ARRL test method)
Selectivity (–6/–60 dB):
CW  500 Hz –6/-60 dB: 500/640
SSB 2.4 kHz –6/-60 dB: 2.39/2.54
AM  6.6 kHz –6/-60 dB: 6.60/6.74
Image Rejection:
70 dB or better (160 - 6m Amateur bands)
Certifications:
CE Declaration of Conformity (25-August-2007) for the FLEX-5000A
CE Declaration of Conformity (23-August-2008) for the FLEX-5000A with RX2 (second receiver)
Specifications are subject to change without notice or obligation, and specifications are guaranteed only within the amateur radio bands.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Tuesday, March 8, 2011
Last Modified By: Administrator
Type: INFO
Rated 3 stars based on 12 votes.
Article has been viewed 33,818 times.
