FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Community
Technical Support
Home
Knowledge Base
PowerSDR
Operating System Information
Windows XP
DPCLAT - DPC Latency Checker Tool
System Dependencies
Minimum
PowerSDR
Version:
All Windows versions
Applicable Hardware:
N/A
Content provided by:
FlexRadio Systems Engineering
This KB article references the DPC Latency checker (dpclat.exe) by Thesycon that can be used to analyze you system for excessive or abnormally long DPC (differed procedure calls) that adversely effect applications that run in real time, such as
PowerSDR
. Below is some information from the Thesycon web site.
The DPC Latency Checker tool determines the maximum DPC latency that occurs on your Windows system and thus enables you to check the real-time capabilities of your computer. DPC Latency Checker works independent of any external hardware. Using this tool may be helpful in the following situations:
You experience interruptions (drop-outs) in a flow of data processed in real-time, for example an audio stream, video stream or a sequence of measuring data, and you want to find out the reason for this problem.
You want to verify that your Windows system is configured properly so that it is capable of handling real-time data transfer before you install the corresponding streaming application.
You want to check
if
a particular computer system is suitable for streaming applications, for example before you buy this system.
If
any kernel-mode device driver in your Windows system is implemented improperly and causes excessive latencies of Deferred Procedure Calls (DPCs) then probably drop-outs will occur when you use real-time audio or video streaming applications.
Use the Related Links below to download the most recent version of the DPC Latency Tool, how to use it to determine
if
you have excessive latencies possible strategies to resolve the problems resulting from excessive DPCs
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Related Links
DPC Latency Checker home page
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Monday, June 20, 2011
Last Modified By:
Administrator
Type:
Software
Rated 4 stars based on 3 votes.
Article has been viewed 24,056 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2021
Execution: 0.234.
8 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
