Virtual Serial Port Driver (vCom)
Expand / Collapse
System Dependencies
Minimum PowerSDR Version:
1.4.0
Applicable Hardware: N/A
Content provided by: FlexRadio Systems Engineering
vCOM driver build 226a written by N8VB.
vCom is use to create virtual com ports (null modem cables) to allow CAT and keyer control to other programs from PowerSDR
vCOM is a virtual Com port, like your RS-232 port. You can use it to have PowerSDR communicate with another application, like Ham Radio Deluxe, without adding hardware Com ports and making jumper cables to go between the Com ports; each application wants its own, dedicated Com port.
CAUTION: This program only works properly on Windows XP, it is a 32-bit application only and is no longer updated by the author.  It is recommended that you use an alternate virtual comport/null modem software application if you are not using Windows XP.
Also see the VSPManager or Com0Com virtual serial port driver as an alternative to vCom.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
vCom Driver Install Package (version 226a)
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Monday, March 29, 2010
Last Modified By: Administrator
Type: Software
Rated 4 stars based on 2 votes.
Article has been viewed 25,472 times.
