Officially Supported Sound Cards For the SDR-1000
Expand / Collapse
System Dependencies
Minimum PowerSDR Version:
  1.8.0
Applicable Hardware:   SDR-1000
Content provided by: FlexRadio Systems Engineering
Not all sound cards have sufficient dynamic range nor do some properly support the Windows mixer controls. For proper operation it is important to use a sound card that has been certified to work with the SDR-1000. Use of sound cards other than those posted there are at the users own risk. The following sound cards have pre-configured setup values for PowerSDR. It is highly recommended you use the preferred sound card in order to get the maximum performance out of the SDR-1000.
Manufacturer
Model
Bus Type
Notes
M-Audio
Delta 44
PCI
Preferred
PreSonus*
Firebox
Firewire
Edirol
FA-66
Firewire
Preferred
* Know firmware bug limits performance when running at 96 KHz sampling rates.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Wednesday, October 28, 2009
Last Modified By: Administrator
Type: INFO
Rated 3 stars based on 2 votes.
Article has been viewed 7,833 times.
