Do I need to log into the Knowledge Base?
Expand / Collapse
System Dependencies
Minimum PowerSDR Version:
N/A
Applicable Hardware: N/A
Content provided by: FlexRadio Systems Information Management Team
No, you do not have to log into the Knowledge Base at this time to read any of the articles.
The Knowledge Base software and the Forums are provided by the same source and there is active development underway to integrate both products together where they share the same user authorization and credentials database. At that time, your Forum login will be the same as the Knowledge Base login and you should be logged into both with a single login process.
Once we have a single login solution, we will be providing users access to Knowledge Base features such as being able to submit content on-line using a workflow approval process. But those enhancements are in the future, so you do not have to worry about logging into the Knowledge base at this time.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this article:
Add Your Comments
Email Address:
Web Address:
Verification Code:
Details
Last Modified:Friday, August 1, 2008
Last Modified By: Administrator
Type: INFO
Rated 1 star based on 1 vote
Article has been viewed 4,022 times.
