How to Effectively Use the PowerSDR AF [Gain] and AGC-T (AGC...
Expand / Collapse
How to Effectively Use the PowerSDR AF [Gain] and AGC-T (AGC Threshold) Controls
System Dependencies
Minimum PowerSDR Version:
1.10.0
Applicable Hardware: FLEX-5000
Content provided by: Tim (W4TME) and Dale (WA8SRA)
There have been numerous questions asked related to the use of the AGC-T (AGC threshold) control on the PowerSDR console. As compared to a traditional radio, the AGC-T control acts like a RF gain control. To effectively describe what the AGC control really is, how it works and how best to use it, you must also include the interaction with the AF [gain] control as well.
Both the AF and AGC-T controls are found on the left side of the PowerSDR console. See the red box in the graphic below.
In a traditional radio, the RF gain is controlling the gain of one or more IF stages in the receiver. A software defined radio does not have an IF amplifier stage, so the PowerSDR AGC-T control is not exactly equivalent to the RF gain control on a traditional radio, but the resulting behavior is similar.
Quoting from the PowerSDR Operations Manual
“[The AGC] control sets the maximum gain of the AGC. [..snip..] Although strictly speaking this control does not set the RF gain, it is denoted as such on the front console as its operational use is identical to that of a true RF gain control.”
So what is the most effective way to use the AGC-T control in PowerSDR?
The AGC-T control is used to maximize the signal to noise ratio (S/N) based on band conditions (QRN). As you reduce the AGC-T, there is a “sweet spot” where weak signals will appear to “jump out” of the noise. This enhances the reception of weak signals.
The customary technique with traditional radios is to utilize the RF gain instead of the AF gain to set your listening level. With software defined radios, as the AGC-T is reduced, you will notice a greater difference in volume level between stronger and weaker signals since the gain is not being increased for the weaker signals. This increase in dynamic range can help to reduce listening fatigue since the lower-level background noise tends to be reduced even further relative to other signals.
This may not always be desirable however. For example, consider participation in a round-table. You may find that this large difference between signal volume levels causes you to keep adjusting your AF [gain] constantly, in order to compensate for the very quiet (yet very readable) stations, and the louder stations. In that case, you may want to increase the AGC-T and back off on the AF [gain] so that the volume levels of all signals will be much more uniform – although with a higher background level on the weaker stations.
In practice, you want to set the AGC-T control as low as possible to comfortably hear the signal of interest. But be careful, if you reduce the AGC-T too much, you loose sensitivity
Step-by-Step Procedure
  1. Set the AGC-T control to 90 (default setting)
  2. Set the AF [gain] control until you have a little more volume than you normally use to listen to the radio.
  3. Leave the AF [gain] setting as is and decrease the AGC-T until you achieve a comfortable listening volume.
  4. For weak signal reception, you may have to increase the AF [gain] a little bit if you have to decrease the AGC-T more than usual so that you can hear the signal in question
This is a great technique for working CW and narrow bandwidth digital modes, such as PSK31 when using a very narrow RX filter (less than 100 Hz). Selecting a small filter can increase the power within the passband of the filter. Reducing the AGC-T will significantly improve the S/N ratio making the filter more effective for weak signal reception, and will greatly reduce the psycho-acoustic perception of ringing that naturally occurs when using extremely narrow filters. Careful adjustment of the RF Gain level while using very narrow filters, in conjunction with the DSP NR function, can allow copy of signals that are virtually at the noise floor.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Wednesday, March 31, 2010
Last Modified By: Administrator
Type: HOWTO
Rated 4 stars based on 6 votes.
Article has been viewed 21,899 times.
