FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Register
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Forums
Technical Support
Home
Knowledge Base
FLEX-5000 Transceivers
Firewire Interface
Selecting High Performance Firewire Cards for FlexRadio...
Firewire
Cards for FlexRadio Transceivers
System Dependencies
Minimum
PowerSDR
Version:
N/A
Applicable Hardware:
Any
Firewire
based
SDR
Content provided by:
FlexRadio Systems Engineering
If
you are considering using a non-motherboard
Firewire
host adapters for the FLEX-5000, FLEX-3000 or the
SDR
-1000 using a
Firewire
based sound card, look at "high end" DV certified
Firewire
host adapters. These will provide the best performance and compatibility. Many, but not all motherboard integrated
Firewire
host adapters are not well suited for real-time audio applications because they share IRQs with many other integrated devices, such as
USB
ports. Sharing IRQs with other devices induces unwanted latency and has been known to cause audio drop outs.
NOTE: A lot of poor performance and audio drop outs and freeze up problems have been resolved by switching from using the motherboard
Firewire
interface to one that is installed in the computers peripheral bus (PCI,
PCI-E
, PCMCIA or ExpressCard)
Cautionary Statement: It has come to the attention of FlexRadio Systems' Support that
Firewire
card manufacturers are changing chipsets without notice. Some of these chipset substitutions are ones that are not fully compatible with the FLEX
Firewire
driver. While we try to keep this list accurate ad up to date, it is in the buyer's best interest to verify the chipset utilized in a particular card before purchasing it.
Helpful Hints:
Use a card that is specifically "approved" for DV editing packages. These cards have better stability (free of jitter) and performance than other
Firewire
cards.
It is recommended that the card you get is using an up to date TI or Lucent AGERE FW323 chipset. Some manufacturers are starting to change to VIA for cost reasons. Other chip sets, such as VIA may work fine, but the TI and Lucent products seem to be the most compatible.
For one of these cards, you are going to pay between $15 to $80 (USD) depending on the bus type.
Do not use a
Firewire
card that also has
USB
or any other interface ports integrated on the same card (aka a "combo" card). These are not designed to be high throughput devices are are not best suited for using with FlexRadio Systems'
FireWire
based transceivers.
Do not use
Firewire
cards that are combo 1394a and 1394b host controllers unless you are using Windows 7. The 1394b host bus adapters do not have native support under Windows XP and Vista.
If
your motherboard has a specialized PCI slot for communications (usually it is orange), install your
Firewire
adapter in that slot. These slots usually do not share IRQ (system interrupts) with other motherboard peripherals.
If
your motherboard has a PCI Express 1x slot, this is the best bus type for a
Firewire
host controller since it does not share interrupts with other motherboard peripherals.
Use high quality
Firewire
cables with multiple shields and gold connectors. Also use the shortest cable possible.
If
you have an existing
Firewire
port on your computer, try it out first before buying a different
Firewire
controller.
Buy your
Firewire
card at a local retailer.
If
it doesn't work you can easily return it.
Firewire
Cards Reported *not* to work well with FlexRadio Transceivers:
Adaptec FireConnect 4300 card
Any Adaptec PCMCIA based cards
SYBA-PCI-Express 1x 1394A model SD-PEX-NEC4F
StarTech PCI-1394B_3
StarTech PEX-1394A2 PCI-Express Card
Best Connectivity / Syba SD-PEX30009 & PEX30016 (in newer i5 and i7 PCs)
Bytecc BT-PE1394
PCIe
NOTE: There have been numerous reports of laptop
Firewire
ExpressCards not working with Windows. The FLEX
Firewire
drivers appears to
load
correctly and is recognized by the software, but does not properly send data between the FLEX hardware and the laptop. This problem is most common on Vista operating systems, but has been reported on XP too.
Firewire
Cards Reported to work well with FlexRadio Transceivers:
DISCLAIMER: The
Firewire
cards listed below are ones used by FlexRadio owners successfully with
Firewire
based sound cards (
SDR
-1000) and native
Firewire
SDRs such as the FLEX-5000A and FLEX-3000. These cards may no longer be available from their respective manufacturers nor are they qualified or endorsed component by FlexRadio Systems. FlexRadio makes no claim to their compatibility with your specific system (
PC
) and the cards are not directly supported by FlexRadio Systems. Caveat
Syba
http://www.syba.com/
Model or Description:
Firewire
1394a 3+1 controller
Bus Type: PCI
Recommended for the FLEX-5000A/3000 - Uses the Lucent AGERE FW323 chipset
Confirmed to work with FLEX-5000 on Windows XP-Professional
Best Connectivity - A division of Syba Technologies, Ltd.
Model or Description: Express Card
Bus Type: ExpressCard (34 mm)
Confirmed to work with the FLEX-5000 on Windows XP-Professional
Texas Instrument
Firewire
Chipset XIO2200 Chipset
2-ports
FireWire
1394a with 400Mb/s
Compliant with ExpressCard/34 standard
IEEE 1394-1995 Standard compliant, for High Performance Serial Bus and P1394A Supplement 4.0
1394 OpenHCI Specification V1.0 and V1.1 compliant
Data transfer rate: 100/200/400 Mbps
Fully plug & play and hot plug supported
For Windows 98SE/Me/2000/XP/XP 64-bit/Vista/Win7
Model or Description: PCI 1394a/b
Firewire
card
Bus Type: PCI
Confirmed to work with the FLEX-5000 and FLEX-3000 on Windows7
Firewire
1394b ports x 2
Firewire
1394a port x 1
Transfer rate up to 800Mb/s
Support 32-Bit 33MHz PCI Interfacing
Compliant with 1394 OpenHCI Specification V1.2
Full Backward compatible to
FireWire
400 1394a specification
Support 800/400/200/100Mb/s data transfer rate
TI Chipset
ADS Pyro
http://www.adstech.com/
Model or Description: PCI 64R2 or ADS Pyro PCI 64
Bus Type: PCI (64-bit)
Note: The ADS PYRO PCI 64R2 has replaced the ADS Pyro PCI 64
Confirmed to work with FA-66 on Windows XP-Professional
TI Chipset
SIIG
http://www.siig.com/
Firewire
card
Bus Type: PCI
Many of their
FireWire
host controllers use the TI chipset. Below is a representative picture of a 1394a PCI host controller.
PCI-E
1394a
Firewire
card
Bus Type:
PCI-E
Sonnet
http://www.sonnettech.com/
Modelor Description:
Allegro Express FW400 (FW400-E)
BusType:
PCI-E
Confirmed to work with FLEX-5000 on Windows XP-Professional and Vista
TI Chipset
External power connector for powered devices
Three (3) 1394a 6-
pin
connectors (2 external/1 internal)
RoHS Compliant
Inland Products
http://inlandproduct.com/
Pro
PCI-E
Bus Type:
PCI-E
1x
Confirmed to work with FLEX-5000 & FLEX-3000 on Windows 7
Two external and one internal 1394a connectors
TI chipset
Supports data transfer rates of 100,200 and 400 Mbps
Built-in 4-
pin
power connector for receiving extra power supply
Dynex
http://www.dynexproducts.com/
PCI-E
1394a/b
Firewire
Card
Bus Type:
PCI-E
Supports IEEE P1394b and backward-compatible with 1394a-2000 and 1394-1995 standards
2 port
Firewire
800 ports (1394b)
1 port
Firewire
400 port (1394a)
Built-in 4-
pin
SUNIX
http://www.sunix.com.tw/
Firewire
card
These cards are DV qualified and known to use the TI chip set.
Micro
Innovations
http://www.mi-products.com/
Firewire
card
Bus Type: PCI
Belkin
http://www.belkin.com/
FireWire
1394a ExpressCard
Confirmed to work with the FLEX-5000/3000 on Windows XP-Professional
Delivers single-lane (x1) PCI Express throughput support rates of 2.5Gbps
Complies with ExpressCard 34mm-wide module specification
Built-in 2 external, independent 6-
pin
FireWire
400 ports
Supports 1394 Open Host Controller Interface (OHCI) Specification 1.1
Features IEEE 1394a-2000-compliant ports at 100, 200 and 400Mbps
Equipped with 1 DC jack for using power adapter to provide 12VDC power output
Complies with IEEE 1394 and 1394a
Allows you to connect/disconnect devices without powering down the system (hot-swappable)
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file.You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Thursday, January 12, 2012
Last Modified By:
Administrator
Type:
INFO
Rated 3 stars based on 5 votes.
Article has been viewed 25,867 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2012
Execution: 1.193.
11 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
