SoftRock-40
Expand / Collapse
SoftRock-40
SoftRock-40
System Dependencies
Minimum PowerSDR Version:
  N/A
Applicable Hardware:   N/A
Content provided by: FlexRadio Systems Engineering
The SoftRock-40 is a small, low-cost, good-performing 40-meter "software defined radio" receiver that plugs into a computer USB port and delivers I-Q audio signals to the computer's sound card. It was designed by Tony Parks, KB9YIG and Bill Tracey, KD5TFD as an "SDR sampler project" for hams everywhere to easily try out software defined radio. This way a great many hams can see for themselves the incredible performance that can be achieved by having just a little inexpensive hardware working in conjunction with some powerful (free) software running on the PC. Receiver performance is simply amazing ... MDS readings of of -128 dBm are typical, with the 1 dB compression level at about -20 dBm!
Block Diagram of the SoftRock-40
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this article:
Related Links
Add Your Comments
Email Address:
Web Address:
Verification Code:
Details
Last Modified:Friday, August 1, 2008
Last Modified By: Administrator
Type: INFO
Article not rated yet.
Article has been viewed 15,125 times.
