SDR-1000 Step-by-Step Set Up Guides for New Users Just Getting...
Expand / Collapse
SDR-1000 Step-by-Step Set Up Guides for New Users Just Getting Started
  System Dependencies
  Minimum PowerSDR Version:     1.8.0
  Applicable Hardware:     SDR-1000
Content provided by: FlexRadio Systems Engineering
For new users, once you receive your SDR-1000, it may seem like a daunting task to get the SDR-1000 and PowerSDR operational. Don’t worry. It really isn’t that difficult and to make things easier, there is a “Getting Started” web page that lists step-by-step guides on the FlexRadio web site that will walk you through the steps necessary to get your SDR-1000 up and running in no time at all.
Just make sure you follow the instructions in order and you shouldn’t have any issues. But in case you do run into any difficulties, you can contact one of our FlexRadio support engineers. For additional support help, please use the Knowledge Base Search Feature to locate articles about you specific issue or post your issue to one of the FlexRadio Systems  Forums. And we can't forget the excellent support offered by our users that is accessible from the Reflector.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this article:
Add Your Comments
Email Address:
Web Address:
Verification Code:
Details
Last Modified:Monday, August 4, 2008
Last Modified By: Administrator
Type: INFO
Article not rated yet.
Article has been viewed 2,054 times.
