My Postings to the Reflector are Not Showing up?
Expand / Collapse
  System Dependencies
  Minimum PowerSDR Version:     N/A
  Applicable Hardware:     N/A
Content provided by: FlexRadio Systems Engineering
The most common reason your post to the Reflector is not showing up on the Reflector is because you are sending the e-mail post from an e-mail account that is different than the one you used to sign up for the Reflector.
It is a requirement that all postings for the Reflector are originated from the e-mail account you used to sign up for Reflector posting privileges.  This is an anti-SPAM mechanism to help prevent unwanted e-mail from flooding the Reflector.
The most common problem is people using an e-mail "redirect" account such as the ones offered by the ARRL.  You can not use an e-mail address such as w1aw@arrl.net to sign up for the Reflector.  It must be an actual e-mail address.
Refer to Item #1 in the new-subscriber welcome message e-mail that was sent to you when you successfully subscribed to the Reflector for more information.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this article:
Add Your Comments
Email Address:
Web Address:
Verification Code:
Details
Last Modified:Wednesday, August 6, 2008
Last Modified By: Administrator
Type: INFO
Article not rated yet.
Article has been viewed 3,542 times.
