FLEX-3000 Transceiver Specifications
Expand / Collapse
System Dependencies
Minimum PowerSDR Version:
  N/A
Applicable Hardware:   FLEX-3000
Content provided by: FlexRadio Systems Engineering
General
Rx Frequency Range:
10 KHz - 60 MHz
(Customer provided preselector or appropriately selected low pass filters required to eliminate images when used below 1.8 MHz)
160 - 6 m (specified performance, Amateur bands only)
Transmitter Frequency Range:
160 - 6 m (Amateur bands only)
Frequency Stability:
TBD
Ambient Operating Temperature Range:
14 °F to 122 °F (–10 °C to +50 °C)
Emission Modes:
A1A (CW), A3E (AM), J3E (LSB, USB), F3E (FM),
F1B (RTTY), F1D (PACKET), F2D (PACKET)
Frequency Steps:
1Hz minimum
Antenna Impedance:
50 ohms
Power Consumption:
Rx 1.5A (typ.); Tx (100 W) 25A (max.)
Supply Voltage:
DC: DC 13.8 V ± 10%
Maximum Interconnect Cable Length:
Firewire - 10 feet (3m),
No restriction on DC power cable within voltage tolerance limits under load.
Special EMI/RFI Requirements:
NOTE: Necessary to minimize RFI radiation from the cables attached to the radio
1 snap on ferrite bead on DC power cable,
2 snap on ferrite beads on FireWire® cable
1 snap on ferrite bead on FlexWire™ cable
All beads to be located adjacent to rear panel of radio.
FLEX-3000 Dimensions:
(WxHxD): 12.25” x 1.75” x 12.25” (31.1 cm x 4.4 cm x 31.1 cm)
FLEX-3000 Weight:
(approx.): 9 lbs (4.08 kg)
Transmitter
Power Output:
1 - 100 watts PEP CW and SSB (2 - 25 watts AM carrier)
Emission Modes Types:
A1A (CWU, CWL), J3E (USB, LSB), A3E (AM), F3E (FM), DIGITAL
Spurious and Harmonic Radiation:
160-10m:  -55 dB
6m: -65 dB
SSB Carrier Suppression:
Better than > 70 dB @ peak output
Undesired Sideband Suppression:
Better than 65 dB @ peak output
Audio Response (SSB):
90 Hz @ -3dB / flat to upper limit set by software, Software EQ optional
3rd-order IMD:
160-10m: -31 dB
6m: -30 dB
9th-order IMD:
160-10m: -48 dB
6m: -48 dB
Image Rejection:
TBD
Microphone Impedance:
600 Ohms (200 to 10k Ω)
Receiver
Circuit Type:
Direct conversion, low IF
Intermediate Frequency:
Software selectable from DC to 20 KHz
Sensitivity (preamp off/on):
1.3 / 0.3 µV (-123/-133 dBm in 500 Hz)
MDS (preamp off/on):
-121 dBm (14.2 MHz, preamp off)
-135 dBm (14.2 MHz, preamp-2 on)
-137 dBm (50.125 MHz, preamp on)
IMD DR3 (dynamic range):
95 dB (@ 2 KHz spacing / 14.2 MHz))
IP3:
Greater than +26 dBm (preamp off)
IP2:
+69 dBm (Preamp off)
+45 dBm (Preamp-2 on)
Selectivity (–6 to 60 dB):
CW 500/640
SSB 2.39/2.54
AM 6.6/6.74
Image Rejection:
160-10m: 96dB or better
6m: 71 dB or better
Certifications:
CE Declaration of Conformity received May 2009.
Specifications are subject to change without notice or obligation, and specifications are guaranteed only within the amateur radio bands.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Tuesday, March 8, 2011
Last Modified By: Administrator
Type: INFO
Rated 3 stars based on 13 votes.
Article has been viewed 47,074 times.
