FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Community
Technical Support
Home
Knowledge Base
PowerSDR
Third-Party Software Interfacing
CW Skimmer
CWSkimmer Multi-channel CW Decoder and Analyzer
CW
System Dependencies
Minimum
PowerSDR
Version:
N/A
Applicable Hardware:
N/A
Content provided by:
Alex, VE3NEA
CWSkimmer is a multi-channel
CW
decoder and analyzer for Windows 98/ME/2000/XP that can use direct
I/
Q
data streams from
PowerSDR
for wide band decoding. CWSkimmer can be downloaded from the
Afreet Software, Inc
. web site
Some of CWSkimmer's features are:
A very sensitive
CW
decoding algorithm based on the methods of Bayesian statistics
Simultaneous decoding of ALL
cw
signals in the
receiver
passband - up to 700 signals can be decoded in parallel on a 3-
GHz
P4
if
a wideband
receiver
is used
A fast waterfall display, with a resolution sufficient for reading Morse Code dots and dashes visually
The callsigns are extracted from the decoded messages, and the traces on the waterfall are labeled with stations' callsigns
The extracted callsigns are exported as DX cluster spots via the built-in Telnet cluster server
A
DSP
processor with a noise blanker,
AGC
, and a sharp, variable-bandwidth
CW
filter
An
I/
Q
Recorder and player.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Related Links
Alfreet Software, Inc. web site
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Thursday, February 21, 2013
Last Modified By:
Administrator
Type:
Software
Rated 2 stars based on 6 votes.
Article has been viewed 37,380 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2022
Execution: 0.219.
9 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
