FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Community
Technical Support
Home
Knowledge Base
PowerSDR
Third-Party Software Interfacing
CW Skimmer
CWSkimmer Configuration Without Using Direct I/Q for the SDR-1000...
I/
Q
for the
SDR
-1000
System Dependencies
Minimum
PowerSDR
Version:
1.10.0
Applicable Hardware:
SDR
-1000
Content provided by:
Mark, MØMRR (
web page
CWSkimmer is a neat little program that decodes multiple
cw
signals all at the same time. This is my particular information relating to setting up CWSkimmer to work with my
SDR
-1000 and Edirol FA-66 soundcard.
Prerequisites:
PowerSDR
and the
SDR
-1000 must already be setup to operate
CW
with either a key or using the CWX (keyboard) form to send
CW
A virtual com port (Com0Com or vCom) must be setup for CAT control.
The CAT parameters must be setup in
PowerSDR
(port, baud rate, and number of stop, data and parity bits)
The program can be downloaded from Afreet Software and has a 30 day trial period after which it must be purchased for a nominal fee. Installation of the program is straightforward by following the prompts.
Figure 1
You can see the
PowerSDR
program in CWU mode with standard settings (
VAC
is NOT enabled)
Figure 2 Figure 3
For the Audio settings (Figure 2), I selected:
Signal
I/O
= Edirol FA-66 In 2
Audio
I/O
= Edirol FA-66 Out 1 (not applicable, but it needed a selection)
Left/Right =
Q
/I
For the Radio Settings (Figure 3), I selected:
Hardware Type = SoftRock-
IF
Audio
IF
= 9600,
Sampling Rate = 96kHz (same sampling rate as the FA-66),
CW
Pitch = 600 (same as the Pitch frequency in
PowerSDR
CW
Mode Controls - see Figure 1)
Figure 4 Figure 5
Default settings for CAT control set up to match the CAT configuration in
PowerSDR
for the virtual com port data parameters
Here are a few stations being decoded at the same time - what a neat little program!
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Related Links
M0MRR Home Page
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Thursday, February 21, 2013
Last Modified By:
Administrator
Type:
HOWTO
Rated 1 star based on 1 vote
Article has been viewed 38,981 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2022
Execution: 0.344.
11 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
