FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Register
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Forums
Technical Support
Home
Knowledge Base
PowerSDR
Third-Party Software Interfacing
CW Skimmer
CW Skimmer Configuration using VAC Direct I/Q
CW
VAC
Direct
I/
Q
System Dependencies
Minimum
PowerSDR
Version:
1.14.0
Applicable Hardware:
FLEX-5000/FLEX-3000
Content provided by:
Tim, W4TME
As noted previously,
CW
Skimmer is a program that decodes multiple
CW
signals all at the same time. It uses
I/
Q
data streams for the decoding of multiple
CW
QSOs.
PowerSDR
v1.14.0 and later has the ability to send the digitized
I/
Q
data stream generated by the
SDR
hardware directly to
CW
Skimmer via a
VAC
audio channel. This allows for wide-band reception of
CW
signals.
Prerequisites:
PowerSDR
version 1.14.0.
VAC
4.09 (also listed as v4.90)
PowerSDR
must already be setup to operate
CW
with either a key or using the CWX (keyboard) form to send
CW
A virtual com port must be setup for CAT control. (Com0Com was used for this setup)
The CAT parameters must be setup in
PowerSDR
(port, baud rate, and number of stop, data and parity bits)
Third-Party Software Configuration
Before starting and configuring
CW
Skimmer, you must install and configure
VAC
for digital audio transfer and a virtual com port for CAT control. In this example, Com0Com is used for the virtual com port.
VAC
Installation
Please refer to the
KC
article,
How to Setup Virtual Audio Cable (
VAC
) 4.0x with
PowerSDR
1.x
, for instructions on how to configure
VAC
NOTE: For this configuration, select the Windows
WDM
-KS driver in the
PowerSDR
VAC
Cable setup described in step 6.
Com0Com Installation
Please refer to the
KC
article,
Com0Com Installation and Configuration Guide
, for detailed instruction on how to configure a virtual com port pair.
NOTE: You can also use VSPmanager for creating virtual com port pairs.
PowerSDR
Configuration
Main Console
PowerSDR
is setup in
CW
mode (U is preferred) with
VAC
enabled.
NOTE: Turn *
OFF* Spur Reduction (SR) to prevent a 3
KHz
variation in the
CW
Skimmer frequency readout.
Below is the
PowerSDR
console in
CW
mode configured for use with
CW
Skimmer.
Figure 1
Firewire
Audio Configuration
Set the
PowerSDR
and
Firewire
sampling rate and buffers to 96
KHz
and 1024 respectively.
VAC
Configuration
After installing
VAC
and configuring two (2) audio "cables", start
PowerSDR
v1.14.0 and open the Setup form. Select the Audio->
VAC
tab. Configure the Audio-
VAC
settings as shown below.
Make sure the Direct
I/
Q
settings are set correctly.
Figure 2
CAT Configuration
Start
PowerSDR
v1.14.0 (or higher) and open the Setup form. Select the CAT Control tab. In this example, I have created a Com0Com virtual com port pair 7/17. Configure the CAT Control settings as shown below.
Figure 3
CW
Open
CW
Skimmer and click on the
View
menu option and select
Settings...
Click on the
Audio
tab
For the
Audio settings
(Figure 4),
set it up as shown below
Soundcard Driver =
WDM
Signal
I/O
= Virtual Cable 2
Audio
I/O
= Virtual Cable 1
Channels Left/Right =
I/
Q
Shift Right Channel Data by = 0 samples
Figure 4
Click on the
Radio
tab
For the
Radio Settings
(Figure 5),
set it up as shown below:
Hardware Type = SoftRock-
IF
Audio
IF
= 9600 (calculated from the 9000 Hz
PowerSDR
IF
+ 600 Hz
CW
sidetone offset = 9600 Hz)
Sampling Rate = 96kHz (same sampling rate as
Firewire
hardware driver),
CW
Pitch = 600 (same as the Pitch frequency in
PowerSDR
CW
Mode Controls - see Figure 1)
Figure 5
Click on the
CAT
tab
Select
Use Radio 1
and click on the
Configure
... button
For the
Rig 1
Settings (Figure 6), set it up as shown below:
Rig Type =
PowerSDR
Port = Com 7 (the other half of the virtual com port pair)
Baud Rate = 9600 (matches the
PowerSDR
CAT parameter)
Data Bits =8
(matches the
PowerSDR
CAT parameter)
parity = None
(matches the
PowerSDR
CAT parameter)
Stop Bits = 1
(matches the
PowerSDR
CAT parameter)
RTS = High
DTR = High
Poll Int, ms = 500
Timeout, ms = 4000
Figure 6
CW
Skimmer In Operation:
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Tuesday, January 25, 2011
Last Modified By:
Administrator
Type:
HOWTO
Rated 5 stars based on 1 vote
Article has been viewed 9,056 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2012
Execution: 0.769.
13 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
