FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Register
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Forums
Technical Support
Home
Knowledge Base
PowerSDR
Software Utilities and Drivers
What is a virtual com port or null modem emulator?
System Dependencies
Minimum
PowerSDR
Version:
1.X.0
Applicable Hardware:
N/A
Content provided by:
FlexRadio Systems Engineering
First a little background.
A communications (com) port or serial port is a physical interface, usually defined by the
RS-232
standard for communicating digital data (bits) between a DTE (Data Terminal Equipment) and a DCE (Data Communication Equipment) one bit at a time or serially, hence the name "serial port". As this relates to ham radio a devices like a computer or older terminal are considered DTE devices whereas your
TNC
or radio are considered DCE devices. A standard
RS-232
serial cable is used to connect a DCE device to a DTC device via their serial or com ports.
If
you wanted to connect two DTE devices together, such as two computers, a special type of serial cable is required called a
"null modem"
cable. With a null modem connection the transmit and receive lines are cross-linked.
Null modems cables are commonly used for data transfer
between
computers or two software packages running on the same computer.
With a traditional radio, where the computer running a ham radio software program that communicates with a radio, this is accomplished with a standard serial cable and the process is fairly straightforward.
With a
software defined radio
, the "radio" is not discrete hardware,
but another software program
. So
if
you want your
to communicate with a ham radio specific program such as a logger that is CAT enabled,
you would need a serial cable that connects a computer to a computer
. By definition this is a null modem cable. Now it doesn't matter that the computer-to-computer connection only involves one computer since the software programs themselves are the ones using the actual serial ports. It just so happens that they can be and usually are on the same computer when operating a
. This is a very important concept and is the crux of understanding why a null modem cable is needed when connecting a
SDR
(program running on a computer) to another program running on the same or different computer.
So,
if
I
am
using a single computer with two serial ports, I can assign the first serial or com port to the
SDR
software, like
PowerSDR
and the second serial port to the logger program and connect a physical null modem cable between the com ports and that would allow the two programs to communicate with each other. Since I need to use two com ports to facilitate the communication path described previously, I refer to this as a
com port pair
or
a null modem connection.
Although this works just fine, the null modem cable makes the computer more susceptible to
RFI
because of the physical cable looped between two com ports makes a nice antenna.
Since the two software program reside on the same computer, there must be a way to allow them to communicate using the computer's internal memory rather than a bulky cable and physical communications ports installed in the computer. And it just so happens there is! A special software package that
emulates
a physical com port in software is called a
virtual serial port
and allows you to add serial ports to your computer without adding additional physical hardware (such as expansion cards, etc.). Unlike a physical serial port the virtual serial or com port can be assigned any name (COM254). It is possible to create an almost unlimited number of virtual serial ports in your
PC
. The only limitation is the operating system running on the computer and the consumption of computer resources, as it may require a substantial amount of resources to emulate large numbers of serial ports which may adversely effect overall computer performance.
As noted above, we require
two serial ports
and a
null modem cable
in between them to allow our
SDR
to communicate with another software program. A special type of software that combines two virtual serial ports together and allows data to pass between them is known as a
virtual com port pair
or
null modem emulator.
See the diagram below.
Fortunately there are several open source and free virtual com port pair/ null modem emulator software packages along with several commercial software packages that can be used to create this virtual connection between software programs running on the same computer.
The original virtual com port pair software package used with
PowerSDR
is called
vCom
. Recently, a lot of people have started using a package called
Com0Com
because it is currently being supported and updated by the software developer and is more compatible with Windows Vista. It has become the
de facto
virtual com port software used with FlexRadio Systems software products.
You can find out more about these two software packages and how to configure virtual com port pairs using several articles found in the Knowledge Center
Virtual Serial Port Driver (com0com)
Com0Com Installation and Configuration Guide
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Wednesday, November 05, 2008
Last Modified By:
Administrator
Type:
INFO
Rated 5 stars based on 1 vote
Article has been viewed 6,280 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2013
Execution: 0.441.
13 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
