FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Community
Technical Support
Home
Knowledge Base
FLEX-3000 Transceiver
Initial Setup and Configuration
FLEX-3000/1500 Microphone Pinout Configuration
System Dependencies
Minimum
PowerSDR
Version:
N/A
Applicable Hardware:
FLEX-3000 & FLEX-1500
Content provided by:
FlexRadio Systems Engineering
The FLEX-3000 and FLEX-1500 use a modular 8-
pin
modular
connector
or "jack" for interfacing a microphone to the
transceiver
. This connector is a modular "8P8C" (8 position/8 contacts) connector. A corresponding 8P8C
plug
is needed, commonly referred to as a RJ-45 plug or connector, for connecting a microphone to the FLEX-3000/1500.
This plug is commonly used for twisted pair Ethernet cabling applications.
The RJ-45 plug has the eight (8) contacts or pins numbered 1 through 8 as shown in the diagram to the right. The contacts are numbered sequentially starting from 1. When viewed head-on with the retention mechanism (clip) on the top, jacks will have contact number 1 on the
right
and plugs will have contact 1 on the
left
Below is the contact assignments or "pinouts" for the FLEX-3000/1500 microphone.
Pin
Number
Function
Increase the
VFO
frequency up by the Tune Step value
2
Decrease the
VFO
frequency down by the Tune Step value
3
Vcc (+5
VDC
4
Microphone Ground (mic -)
5
Microphone In (mic +)
6
PTT
PTT
7
PTT
Ground (
PTT
8
Change to the next Tune Step value
The FLEX-3000/1500 uses the same connector pinout as the Yaesu FT897, FT857 and FT817
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Saturday, February 27, 2010
Last Modified By:
Administrator
Type:
INFO
Rated 4 stars based on 10 votes.
Article has been viewed 24,839 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2022
Execution: 0.331.
12 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
