FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Community
Technical Support
Home
Knowledge Base
FLEX-3000 Transceiver
Third-Party Hardware Interfacing
FLEX-3000/1500 RJ-45 Mic to W2IHY Audio Interface Configuration
System Dependencies
Minimum
PowerSDR
Version:
N/A
Applicable Hardware:
FLEX-3000 & FLEX-1500
Content provided by:
FlexRadio Systems Engineering
The following wiring diagram represents how to wire the modular FLEX-3000 & FLEX-1500 RJ-45 8-
pin
microphone connector to the W2IHY EQplus and the 8-Band EQ using the 5-
pin
DIN connector.
NOTE: Connect the GROUND (GND) to the cable shield but do not connect it to the shield of the DIN connector
FLEX-3000/1500 Microphone Pinout Configuration
Pin
Number
Function
Not Used - Reserved for future use
2
3
Vcc (+5
VDC
4
Microphone Ground (mic -)
5
Microphone In (mic +)
6
PTT
PTT
7
PTT
Ground (
PTT
8
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Friday, July 15, 2011
Last Modified By:
Administrator
Type:
HOWTO
Rated 5 stars based on 1 vote
Article has been viewed 28,154 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2022
Execution: 0.297.
16 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
