FLEX-3000 Power Up/Down Procedure
Expand / Collapse
System Dependencies
Minimum PowerSDR Version:
  N/A
Applicable Hardware:   FLEX-3000
Content provided by: FlexRadio Systems Engineering
To Power Up the FLEX-3000, execute the following steps in order:
  • Turn on the Power on the FLEX-3000 by pressing the Power LED switch all the way in until it clicks.
  • After a few seconds, the power relay will click and the power switch LED will illuminate.
  • Start your computer.  Wait for it to completely boot up
  • Start PowerSDR.
  • Begin using the FLEX-3000.
To Power Down the FLEX-3000, execute the following steps in order:
  • Shut down PowerSDR.
  • Power off the FLEX-30003. Press the power button until it clicks and then release.
  • Shut down your computer.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Tuesday, March 24, 2009
Last Modified By: Administrator
Type: HOWTO
Rated 5 stars based on 1 vote
Article has been viewed 5,536 times.
