FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Community
Technical Support
Home
Knowledge Base
PowerSDR
Software Utilities and Drivers
Virtual Serial Port Driver (VSPmanager)
System Dependencies
Minimum
PowerSDR
Version:
1.4.0
Applicable Hardware:
N/A
Content provided by:
FlexRadio Systems Engineering
The Null-modem emulator (VSPmanager) is a 64 and 32-bit
signed
kernel-mode virtual serial port driver for Windows. You can create an unlimited number of virtual COM port pairs and use any pair to connect one COM port based application to another.
VSPmanager is use to allow CAT,
PTT
and keyer control to other programs from
PowerSDR
VSPmanager
is a virtual Com port and virtual null modem cable, like a physical
RS-232
port and a null modem cable. You can use it to have
PowerSDR
communicate with another application on the same computer via a CAT protocol, like loggers and digital mode programs, without adding hardware Com ports and making jumper cables to go between the Com ports since each application wants its own, dedicated Com port linked with a null modem cable.
You can also use a virtual serial port to key
PowerSDR
. Some ham radio digital mode applications use a com port to assert RTS and/or DTR to key a radio. You can do the same thing with
PowerSDR
using a virtual comport. NOTE: THis is not using a CAT command to transistion the radio from receive to transmit and transmit to receive. You are just "bit banging" the serial interface to key the radio and no upper-level communications protocols are being utilized by the com port.
The VSPmanager Project web page is located
here
You can download the software from the project web page.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced.
Rate this Article:
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Saturday, April 17, 2010
Last Modified By:
Administrator
Type:
Software
Rated 4 stars based on 2 votes.
Article has been viewed 18,332 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2022
Execution: 0.234.
13 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
