FlexRadio Systems Knowledge Center
Home
Search
Tags
Glossary
Members
Welcome Guest
Login
Latest Additions
Most Popular
Getting Started
Knowledge Base
TroubleShooter
FAQs
Downloads
FlexRadio Web Site
Community
Technical Support
Home
Knowledge Base
FLEX-1500 Transceiver
Initial Setup and Configuration
Common Installation Problems and Questions
How to Manually Uninstall and Reinstall the FLEX-1500 Device...
How to Manually Uninstall and Reinstall the FLEX-1500 Device Driver
System Dependencies
Minimum
PowerSDR
Version:
N/A
Applicable Hardware:
FLEX-1500
Content provided by:
FlexRadio Systems Engineering
Under rare circumstances where the FLEX-1500 device driver did not
load
properly, as determined by validating the installation using the KB article "
How to Verify the FLEX-1500
USB
Driver is Properly Loaded
", you can manually unload and reload the drivers without having to unload
PowerSDR
. The following procedures will provide a step-by-step guide for repairing a failed driver install.
Complete Uninstall / Reinstall of the FLEX-1500 Driver
Step 1.
- Power off the FLEX-1500
Turn off the power to the FLEX-1500
Step 2
- Locate the FLEX-1500 Driver Install folder.
The FLEX-1500 driver install folders are located with the
PowerSDR
2.x.x application folder. There are separate driver folders for the 32 and 64-bit versions of the driver. Make sure you select the proper folder for the type of operating system you are running.
For Windows XP, the default location for the installation of
PowerSDR
is:
c:\Program Files\FlexRadio Systems\
PowerSDR
v2.x.x
For Vista and Windows 7, the default location for the installation of
PowerSDR
is:
c:\Program Files (x86)\FlexRadio Systems\
PowerSDR
v2.x.x
Using Windows Explorer or any of the alternate methods Windows provides to view and execute files, navigate to the appropriate FLEX-1500 driver folder.
Step 3
- Manually Uninstall the FLEX-1500 driver
Locate the batch file
uninstall.bat
in the appropriate FLEX-1500 driver folder.
If
you are running Vista or Win7, Right click on the file name and choose "
Run As administrator
If
you are running Windows XP, make sure you are logged in with full administrator rights as there is no Run As option for batch files.
You will see a Windows Command window (aka "DOS box") displayed momentarily while the driver is uninstalled.
Step 4.
- Manually Install the FLEX-1500 driver
wd_install.bat
If
If
You will see a Windows Command window (aka "DOS box") displayed while the driver is being installed. It can take up to a minute or two to complete the driver installation. Wait until the Command window closes before proceeding.
Step 5
- Verify the driver installation
Validate the FLEX-1500 driver installation using the KB article "
USB
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require
login
or
registration
Details
Last Modified:
Friday, June 25, 2010
Last Modified By:
Administrator
Type:
FIX
Rated 5 stars based on 1 vote
Article has been viewed 9,019 times.
Print Article
Bookmark Article
Social Bookmarks
Comments RSS
Powered By InstantKB.NET 2.0.6 © 2022
Execution: 0.281.
9 queries.
Compression Disabled.
Search All
Go
Advanced Search
Social Bookmarks...
