How to Configure Fldigi with PowerSDR
Expand / Collapse
  System Dependencies
  Minimum PowerSDR Version:     1.X.0
  Applicable Hardware:     Any FlexRadio Systems SDR
Content provided by: FlexRadio Systems Engineering
There is a detailed "how to" wiki article authored by Brain, WB6RQN/J79BPL that describes the detailed step-by-step procedure for configuring Fldigi with PowerSDR including the virtual com port configuration needed for CAT control of Fldigi and VAC that is needed to transfer audio to and from PowerSDR and Fldigi.
Use the following URL to access the Fldigi wiki article, Using Fldigi with PowerSDR
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Tuesday, August 3, 2010
Last Modified By: Administrator
Type: HOWTO
Rated 3 stars based on 3 votes.
Article has been viewed 19,117 times.
