SAM mode - Explained
System Dependencies |
Minimum PowerSDR Version: |
1.X.0 |
Applicable Hardware: |
FLEX-5000 |
Content provided by: Brian, WB6RQN/J79BPL
It is just a different type of AM detector. Synchronous AM detection (SAM) phase-locks the BFO to the AM carrier and then uses the BFO with product detection. It doesn't suffer from the loss of intelligibility during QSB that a normal AM envelope detector does. But you also can't see zero beat with it either since it will track the AM carrier even if you tune a little bit off-frequency.
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file.
You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Add Your Comments
Last Modified:Tuesday, March 1, 2011
Last Modified By: Administrator
Type: INFO
Rated 2 stars based on 1 vote
Article has been viewed 13,173 times.
