FLEX-5000 Balanced Line-In to W2IHY Audio Interface Configuration...
Expand / Collapse
System Dependencies
Minimum PowerSDR Version:   N/A
Applicable Hardware:   FLEX-5000
Content provided by: FlexRadio Systems Engineering & W2IHY
The following wiring diagram represents how to wire the FLEX-5000 Balanced Line-In (1/4" TRS) and PTT to the W2IHY EQplus and the 8-Band EQ using the 5-pin DIN connector.
NOTE:  Connect the GROUND (GND) to the cable shield but do not connect it to the shield of the DIN connector
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file.You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Friday, July 15, 2011
Last Modified By: Administrator
Type: HOWTO
Article not rated yet.
Article has been viewed 15,859 times.
