Virtual Serial Port Driver (com0com)
Expand / Collapse
Virtual Serial Port Driver (Com0Com)
System Dependencies
Minimum PowerSDR Version:
1.4.0
Applicable Hardware: N/A
Content provided by: FlexRadio Systems Engineering
The Null-modem emulator (com0com) is a 64 or 32-bit unsigned kernel-mode virtual serial port driver for Windows. You can create an unlimited number of virtual COM port pairs and use any pair to connect one COM port based application to another.
Com0Com is use to allow CAT, PTT and keyer control to other programs from PowerSDR.
Com0Com is a virtual Com port and virtual null modem cable, like a physical RS-232 port and a null modem cable. You can use it to have PowerSDR communicate with another application on the same computer via a CAT protocol, like loggers and digital mode programs, without adding hardware Com ports and making jumper cables to go between the Com ports since each application wants its own, dedicated Com port linked with a null modem cable.
You can also use a virtual serial port to key PowerSDR.  Some ham radio digital mode applications use a com port to assert RTS and/or DTR to key a radio.  You can do the same thing with PowerSDR using a virtual comport.  NOTE: THis is not using a CAT command to transistion the radio from receive to transmit and transmit to receive.  You are just "bit banging" the serial interface to key the radio and no upper-level communications protocols are being utilized by the com port.
The Com0Com open source project web page is located here
When downloading Com0Com, make sure you get the proper driver for your operating system's bit depth; 32 or 64-bit.
The 32-bit driver has the text string "i386" in the file name and the 64-bit version has the text string "x64" in the file name.
Examples:
32-bit: com0com-2.2.2.0-i386-fre.zip
64-bit: com0com-2.2.2.0-x64-fre.zip
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
Com0Com Files Downloads
Rate this Article:
Related Links
Add Your Comments
Comment require login or registration.
Details
Last Modified:Saturday, April 17, 2010
Last Modified By: Administrator
Type: Software
Rated 1 star based on 3 votes.
Article has been viewed 65,748 times.
