High Quality USB Cables
Expand / Collapse
  System Dependencies
  Minimum PowerSDR Version:     N/A
  Applicable Hardware:     Any USB based SDR
Content provided by: Tim, W4TME
The utilization of high quality USB cables in any high RF environment is an absolute necessity and not all USB cables are constructed the same.
In addition to keeping unwanted RF out of a computer and a USB connected software defined radioUSB interfaces also have the ability to emit RFI, therefore a well shielded USB cable with ferrite chokes are essential for mitigating RFI issues.
When purchasing a USB cable, it is important to recognize that there are different specifications of USB cables that are delineated by their maximum data rates and the amount of current handling capacity, since USB cables can provide 5.0 VDC voltage to a target device from a host computer.
If you need to purchase additional USB cables for your USB enabled software defined radio, make sure that you purchase cables that conform to the USB 2.0 or higher specification.  These cables are designed for high data rates and in order to achieve these higher data rates with no data loss, better quality materials and and manufacturing to stricter tolerances is required.  To ensure that the cables you purchase have met the required USB 2.0 specifications, look for the certified "HI-SPEED" USB logo shown below on the product packaging.
The USB 2.0 cable shown on the right is an example of a high quality USB cable.
The USB cables provided with FlexRadio Systems software defined radios are of very good quality and are sufficient for most applications.  If you have a situation where the SDR is in a high RF environment, you may want to consider a high quality USB 2.0 cable.
Below are some links to USB cable manufacturers and suppliers that are know to have high quality USB cables.
DJ TechTools (www.djtechtools.com)
Hi-Quality USB 2.0 Cable
USBFirewire (www.usbfirewire.com/)
A-B USB 2.0 Cables
This company has a variety of angled USB connectors.  You may be interested in an "up angle B" connector for use with the FLEX-1500
Tendon (www.tendonusq.com)
USB 2.0 Cables
This KB article may reference additional files that are available on the FlexRadio Systems web site Downloads page. Please use the URL(s) below to download the referenced materials.
An Adobe Acrobat Reader may be required to open the file. You can download Adobe Acrobat from here.
KB Source Document(s):
None Referenced
Rate this Article:
Add Your Comments
Comment require login or registration.
Details
Last Modified:Monday, February 15, 2010
Last Modified By: Administrator
Type: INFO
Article not rated yet.
Article has been viewed 9,971 times.
